I am having problems with my safari
I use Safari as my default web browser. Recently it is becoming crash, when I go to certain sites. The problem comes when I visit yahoo mail, I have my main email account in yahoo. And now I can't get into it. I am using Mac OS. Some times I want to reboot for continuing my work.
I need someone's help for solving this.
Best Answer by Ailynhope ato
Answered By 0 points N/A #137366
May be your Safari is crush. So, its better idea that if you re install it again. but when you uninstall the fast one, don't clean the privacy, history, if you want.
When you install again, import everything from options.
Thanks
Answered By -5 points N/A #137367
Plugins such as Java, Silverlight and Flash can be one reason that is causing your Safari browser to crash too often. If the plugins are old, try updating them and see if that works. Another reason might be the updating of Web Kit that is the thing that holds Safari. It should be updated regularly to avoid any future crashes.
