I am having serious problems configuring my PS3 controller to my PC!
I am having trouble configuring my PS3 controller to my PC, i have the Joystick to mouse program and everything is installed and every time i try to test it on the joystick to mouse program! it says Your Gameport or gameport drivers are not properly configured.
Please consult the device manager.
AND i go to the device manger and do everything i know how to possibly do! im really depressed because of this, i need help ASAP 🙁
Answered By 10 points N/A #163034
Hello Waveykid,
To resolve that issue, you will first of all need to make sure that you have properly configured the PS3 Controller in the Control Panel > Gaming Devices.
Just check that and verify the configurations.
The gameport or the gameport drivers being used on your computer may not be configured properly, and therefore you will need to consult the device manager. That implies that you must do the following:
  • You will have to install proper drivers for your gamepad by going to the Control panel and the choose System followed by Hardware tab, and then Device manager.
  • After that you will have to configure your gamepad by going to the Control Panel, and then Gaming Devices.
  • After you have configured you can now use Joy2Key.
Carl
