I am having a trouble copying from USB video windows 7.
Yesterday, I got so many files to be transferred from my laptop through the computer. This is an important file from our company that needs to be done at home.
An .avi file extension video in my Windows 7 OS, after copying the video it seems like the USB didn’t carry the data itself.
How to view hidden files in an USB?
I really need some help.
Waiting for your support.
I am having a trouble copying from USB video Windows 7.
Hi
Try following methods
1. Format you USB driver
Right click on your device and click format
Then copy your data again to your USB drive
2. Usually USB drive has a small write project switch on it. Please check whether it is locked or unlocked
It should be unlocked to copy data to USB drive
If you want to view hidden files in an USB, Please follow below mentioned steps
Option 01. Go to tools > Folder option > view > Enable the “Show all my hidden files”
Option 02. Go to start click on RUN > type CMD > in the CMD window type the letter of your drive
Thanks & Regards
Mckinney Ma
