I am having trouble sending fax with multiple pages
My modem is PCIe Soft Data Fax Soft Ring Modem with Smart CP. It was working fine until recently.
Today I had trouble sending a fax of four pages.
It will start on page 2 then it will hang up on page 3 and gives an error message:
"fax cannot be sent because of an unexpected error."
I must have tried about a dozen times. I went into the Control panel and queried the modem and it seems fine.
Yesterday I ran "deep care" of Advanced System Care 4, maybe could it have messed things up?
Anyway, I would appreciate any help in fixing it and also testing once it is fixed.
Thanks in advanced.
