I am looking for an accessible calendar for windows 8
Hello everyone,
I recently installed Windows 8 on my computer. I have to manage my calendar and schedule.
I need a calendar that can easily be added in my calendar app.
I am looking for accessible calendar for windows 8. Is there any tool or software available that can fulfill my requirements?
It should be available offline and I can access it anywhere online from various devices.
Waiting for your best suggestions.
Answered By 0 points N/A #150474
Hello Alan,
The calendar App in Windows 8 lacks functionalities but makes it up in the UI. the best replacement for the Windows 8 calendar App would be the Google Calendar. You can integrate the Google Calendar into the Windows 8 Calendar by
  • First opening the Calendar App and then press "Windows + I" to open the Settings Menu.
  • next Select Add an Account and Select GOOGLE.
  • The Google authorization page appears. Enter your account details and press Enter.
  • The calendar app should sync to the Google Calendar.
Once synced you can use the Google Calendar through the Calendar App and enjoy its services both online and offline. The work done offline would be synced back when online. Cheers.
