I am looking for a free jQuery iTunes style carousel.
Hello! I have been working on a website that includes iTunes downloads. To make it robust and good looking, I have incorporated jQuery into it. I would like to download jQuery iTunes style carousel to add to my website so as to have an effective website. Any other jQuery iTunes plugins will also be appreciated. Thanks to you.
Best Answer by Walker Burkhead
Answered By 0 points N/A #142333
Jquery carousel software does make your site more appealing and helpful, you can try Jquery Gallery Slider Generator 1.0. It can convert various of photo and MP3 file into animated Jquery image gallery. This Jquery best image gallery can stand-alone embedded in your HTML site. Jquery galley is easy to install, manipulate, customize and work with.
Answered By 0 points N/A #142334
There are several JQuery iTunes plugins which you can select. One of this is a wrapper to Apple search API. Its a little plugin where in you can easily query to iTunes store, Mac Apple Stores and even ibook Stores straight from your JQuery. It i as a very simple plugin but made your shopping at any application stores you like more convenient.
