I am not able to connect with Verizon Wireless
Initially my LTE dropped out completely and there was no service. Then I found 1x and now only 3G is available. Slowly the scenario is becoming worsened. I find no connectivity for a while again and no service again. I am really frustrated without the service. Is anybody else experiencing the same? Any solutions please update.
Answered By 590495 points N/A #131740
I guess you should check the network coverage around your area because if your phone can’t receive any signal then your current location has poor signal coverage. Since it is a problem with the signal reception, the fastest and easiest way to fix it is to contact your network provider.
If you are subscribed to Verizon, you should contact them and relay your issue. Signal reception is a normal problem with mobile phones because sometimes the signal goes down very low and there are times it totally disappears. Network-related issues are caused, most of the time, on the part of the provider.
Because sometimes they need to do maintenance and it affects the strength of the signal and sometimes the connectivity. When there is a disruption in your connection or with your signal, you should contact your network provider so you will know if they are doing some maintenance around your area.
Your connection will be restored once they are finished with the maintenance.
