astha75
10 points
Posted on - 01/25/2013
Dear Experts,
While I use Hindi font 'Mangal' in MS Excel it works fine. I am getting ??? marks instead of text while saving the document in CSV format. Please Help I there is any solution for my problem.
Thanks a lot for your valuable time.
Astha
I am not able to maintain font format in CSV document
Hi!
I have analyzed your important question.
The question marks are normally seen when excel does not recognize the cell content.
You should install your required font in the system font unit.
You can do it by copy your font file to control panel/fonts directory.
Check the font in the Excel font list.
Write down anything using this font.
Then you can easily save it as csv.
No question mark will be seen.
Thanks
Nowell
Hi Astha,
Whenever you use Mangal or any different language font so you should to save like you are saving CSV format but the issue is that when you change language English without saving your format file so it gives an issue so you should to save file format after and before changing fonts. Hopefully this information will help you.
Thanks,
Raun Nelson
