I am an ad film maker. I need to watch short films in my system and find the technical defects in it. It was good all the time, but after my recent system reboot, I am not able to watch the movies.
It is asking to adjust the screen resolution in control panel display settings. It is spoiling my work as I have set some goals to finish off the job.
Please help me.
Thanks in advance.
Hello Dear,
Thanks that you have shared your problem with us.
Dear it seems that your adobe flash player has been crashed.
You have to reinstall adobe flash player. So that you can watch movies.
You should install adobe flash player 11. It is the more accurate version of flash player.
You can download it from here.
https://get.adobe.com/flashplayer/
I hope it will help you a lot.
Thanks
Hey Grace,
You need to adjust the screen resolution in control panel display settings.
Once you have done this, get your adobe flash player 11 from this link:
https://get.adobe.com/flashplayer/ or try to type adobe flash player in the
start box of your computer then reinstall it.
Thanks,
Steele
Hello dear,
It is so sad that you have not installed the proper flash player. If you have installed it already, then you have updated it from a defective source. You should uninstall your current version and install a new one. I suggest you download this flash player. I have posted its download link here. You can download it by clicking on it.
http://download.cnet.com/Adobe-Flash-Player/3000-2378_4-10001055.html
I hope this will help you. Thanks.
