Yohjc
Posted on - 09/30/2011
I am planning on buying a new wireless printer so that I could print using my laptop without the hassle of being connected to the printer always.
Before I buy one, I would like to know if connecting the printer would be easy. How do you get a printer to go wireless?
Mykee
I am planning on buying a new wireless printer. Need help
Hi. Definitely, it will be easy to install or connect a printer through a wireless connection. The first thing that you need to check is that the printer you are going to purchase is wireless capable. You should have a computer that is already connected wirelessly. The first step to set up the printer is to load the driver software. When you have it successfully installed, you need to have the computer search for the wireless printer and have it added as a device. To do this, here are the steps: go to HARDWARE AND SOUNDS (start-control panel), under the option DEVICES AND PRINTERS, click on ADD A PRINTER, lastly you have to select ADD A WIRELESS PRINTER.
Generals
You don’t need to buy a new router. The only thing you need to do is to connect your printer to a network through your router so that no more wire/cables are needed to access your printer. I guess you have desktop at home. And to answer your question if it is easy to make a printer to become wireless. Yes it is easy.
