kunigonda
Posted on - 11/03/2011
Good day!
I am seeking for help regarding Macros.
I’m using a Macro for fancy chart purpose.
I also need a macro which is slightly different from this.
Now, I have to customize every time I want it. if I can make a copy and edit, it will be very useful.
Please, Anybody knows???
Thank you…
Hallo Kunigonda,
If you want to customize the macros that you are using for fancy chatting for other purposes apart from that, then you will need to play around with the code and the modules that are used in designing those macros. Some other activities that you can use the macros for include creating sound effects, animating characters and creating text bubbles just for fun.
I have listed for you two links below where you can find a detailed elaboration on how you can use the macros for those other activities and customize them as you like.
Informational Site 1
Informational Site 2
Hope this helps.
__
Regards
Mahesh Babu
