I am in trouble with my Laptop Battery.
hi my Laptop is not working properly from last few days. When I turn my laptop on some time it show a message, "Replace the battery". But some time it work properly. Why it is happening?
Some time it is working properly means your laptop battery is good. May be it is troubling due to connection problem. Check your laptop battery connector and plugged it properly.
One more suggestion for avoid laptop battery problem, "Never charge your battery for whole day, only charge after becomes low".Â
Hi Namya,
I beg to differ with Sammd's comment. Your laptop battery is faulty and needs replacement as soon as possible. This is a normal behavior that most batteries tend to have when their lifetime span is coming to an end. You are even lucky that it is behaving this way as other types of batteries just stop working without warning.
Consider replacing your battery for you to keep your laptop hardware safe. Any more strain to the battery might damage other hardware such as the hard disk and memory chip.
Hi Namya,
               I think that your battery still work fine. You can only tell that your battery is damaged when it’s discharging time become very fast. I think that the problem of your laptop is not the battery itself. I think the problem is in the connection of your battery and laptop. Sometimes it became loose or dirty. When these errors pop up again in your screen, try to unplug your battery and re install it again. If the error was fixed, it is sure that the error comes from it. Try to clean all the connector pins and re align it again.
