Thenel
Posted on - 09/16/2011
I am trying to connect my Blackberry to my network wirelessly but it doesn't seem to connect.
I tried it on a hotspot and it does the same thing. Is there an update for Blackberry phones? How can I update it myself?
Updating the Blackberry device does help eliminate incompatibility issues. This fixes problem with Internet connection connecting to the wireless network, in Wi-Fi free hotspot of home networking.
* Connect the device to the USB Mac Computer or Windows
* Go to BlackBerry Desktop Manager in the Application Folder
* Click Backup at the very top of BlackBerry Desktop Software then an instructions will guide you through
* Then click Applications and Start the software
* Click Updates and perform the steps in selecting the new versions, click Show other Versions.
You may also visit blackberry.com for the latest updates.
Here is a procedure to help you troubleshoot the wireless network connection problems that your blackberry device is having:
You will need to open the BlackBerry device, and then in the device options, you will click on Wi-Fi Connections.
You will then Press the Menu key.
And then you will click Wi-Fi Tools followed by Wi-Fi Diagnostics.
You will need to verify the information in the status fields for the following connection groups:
Wi-Fi
VPN
UMA/GAN
BlackBerry Infrastructure
Enterprise
In case you need to have a look at more diagnostic information, then you will need to press the Menu key and then click Options. You will then locate the Display Mode drop-down list, and from the choose Advanced.
-Clair Charles
