Hello Friends,
I am unable to install and run my newly bought Logitech camera when I try to run after installing it gives the following error can anyone help in this regard?
I will thankful for all help and support.
USB PC Camera (ZS0211)
>SetupDLLSetupDLL.cpp (409)
$7.0.100.1342
@windows service pack 1 (6001) BT_OTHER 0.0
This error occurred because the driver of your Logitech camera, you installed, doesn’t compatible with your Windows Os. You should install a driver which is compatible with your system. You can find compatible Logitech driver according to your system by searching the internet. Download it and install it. Hope your problem will be solved. Here's a link for you:
https://logitech-webcam-software.en.softonic.com/
From here you can download the drivers
