I am unable to save file as text file.
The following error message appeared while I tried saving a file as a text file: “Unable to save your template as a text file”. I am however succeeding in saving all other files as text files. Why can’t I save the said file in text format?
Answered By 5 points N/A #109293
Hello There,
If you want a normal template to be saved as text file then simply open the template in its compatible software, default program or recommend program. After the opened text matter is in readable format, copy all the texts.  Open the text editor and paste the  readable text  there. Simply save this file as text format.
When you use “global template as manager”, make sure that you use right path for saving file.
So, basically select and copy text and paste it in text editor. Then save it.
Note: Some of the information of the template varies. Some information cannot be read, cannot be converted into text file and cannot be saved as text file.
