I Am Unable To Connect To My Printer; It Shows 0x00000002 Error Code. Someone Facing This Problem?
0x00000002 error is a BSOD error message. The debugger has forced the device to a ready state and recovered debug control, but your application’s state is now corrupt. You should have limited access to register and memory, but the device should be reset to debug further.
The symptoms of code 0x00000002 are the user will get a complete blue screen with the brunch of the words describing ‘Connect to the Printer: Windows cannot connect to the printer. The operation failed with the error 0x00000002’ and numbers that will indicate a serious error. The cause of code 0x00000002 is the BSODs, which is generally caused by faulty hardware or software corruption.
The steps to fix the 0x00000002 error code is as follows:
