bmcaro
10 points
Posted on - 06/29/2012
Always I get the following error as I try to uninstall Vuze from my computer.
An error has occurred:
java.io.FileNot FoundException: C:Program Files (x84)Vuze.install4jfiles.log (The system cannot find the file specified)
Error log: C:….Tempinstall4jError6654729157156916831.log
Currently I am using Windows 7 64bit.
Please do give me your help to solve this.
I am unable to uninstall Vuze. Can anyone help?
For you to remove programs without going to list of programs installed to your computer, you need to uninstall it manually. For you to do that, you must be familiar with registry, because you need to deal with it if you are going to delete manually. go to C:Program Files then look for the folder of Vuze, then delete the folder. After deleting to the program files go to registry. To go to registry, Click Start then type to the search box “regedit” then press enter.
Locate the following path and then delete.
HKEY_CURRENT_USERSoftware Vuze
HKEY_LOCAL_MACHINESOFTWAREVuze
After delete, restart your pc Good luck.
