I Am Using An Internet Cable For Xbox 360. Any Help?
I am m using an internet cable for xbox 360. I have heard that the first time users need to follow a few precautions to be careful. Any help? What do I need?
For setting up a wired connection for your xbox 360, you will need the following things:
● A network cable
● A router, gateway, or modem
● A high-speed Internet connection ( for example cable or DSL)
Then, follow the steps below:
1. Take one end of the cable and plug it into your modem.
2. Plug the other end to your Xbox console. (See the picture below for a reference on how your setup should work)
3. Turn the Xbox console off.
4. From the back of the modem, unplug the cable
5. After 1 minute, you need to plug the modem back in and then wait till the lights return to the normal state.
6. Finally, turn on the Xbox console.
