Green Scott
50 points
Posted on - 10/05/2012
Hello Guys,
I began experiencing this problem around as soon as it became 2012, but I can’t find any help on this. This long error message showed up. Does anyone here know what to do with it?
I experienced computer problems a few days ago and disabled some things in start-up, Maybe there was a setting there that I wasn’t able to turn on again???
T hanks a bunch, I really appreciate the help.
Hello Green,
You might want to cross-examine the particular application that is causing the issue that you are getting. It is most likely to be the one that has got bugs and as a result causing that issue. A reinstallation may fix the issue. Also check for compatibility issues with the operating system that you are using.
Nicke
LyanaHay
Hi Scott,
 I had solution to your problem although you haven't mentioned what exact problem you are facing. If you could it will be great.
You mentioned that you are facing problem since you have made some changes few days back. I will suggest you some steps:
1] Go to control panel
2] Check for system restore option
3] Go to particular point as per date where you can find your computer was stable on that particular date.
4] Restore your system to that date.
5] Done.
