Arlet Joson
10 points
Posted on - 01/16/2012
My HTCTouch Pro 2 has 10 years calendar entries. Using Active sync I previously sync it with outlook. I bought an iPhone 4 and I want the calendar over to it but it is not working I don’t know why. Can anyone fix it?
Hello Arlet Joson,
I have read your issue regarding on how to put calendar on your iPhone. The device from apple has a built in application of calendar. You can check the menu for the calendar application. Another option for you is to get the Google calendar also.
We can get Google Calendar Sync Settings by opening your Safari from your iPhone. It is a quick and easy way also to get this application. I have attached a picture of how it would look like. This will fix the errors for your calendar application form your iPhone. Then you can get started using the calendar App on your device.
Hello Arlet,
Microsoft does provide a built-in solution for Outlook and iPhone syncrhonization. You will need iTunes to perform this one-time setup and synchronization. Once you have connected the system with iTunes you need to go under devices and follow the steps given on microsoft support website. If you encounter any problems during the installation and usage, you can search from extensive support website of Apple here. It also depends on the version of you iPhone OS. I hope it works for you otherwise there are other syncing solutions available like Remember the Milk.
Hopefully it works out fine for you.
Abe.
Hi Abe. You sure have a lot of idea about. I've seen all the links you've sent me. And all are very useful.. Got no problem now on my Iphone calendar. You're my angel. Thanks
