I came across an Error 1612 prompt
While trying to uninstall my NI program, I came across an Error 1612 prompt.
Shown below is the actual snapshot of the encountered error prompt:
Installer Error
Error 1612 occurred. Would like to continue this operation?
Yes No
Answered By 20 points N/A #121145
Hey Bart Jones!
If you are facing this error there is a possibility that your windows cache is corrupted. You need to fix it. There are many softwares on the internet that can fix it. You can download any of them but I am also going to add a link here for you. You can download the software from the link.
http://digital.ni.com/public.nsf/$CXIV/ATTACH-AEEE-8R4QYS/$FILE/MSICacheCheck.exe
I also had the same problem and I come to know that the Cache of my windows is corrupted. I installed the same software to get rid of this error. And I was really succeeded and did not face this error message anymore.
I would like to suggest you the same thing which I did. Just download the software and fix your corrupted cache.
Thanks
Answered By 590495 points N/A #294967
That’s an installer error which can happen when you are installing or uninstalling a program. Since it seems you are uninstalling a program when the error pops up, proceed with the operation and click “Yes” to continue. But in case the operation stopped and you can no longer uninstall the application because of the error, one way of fixing it is to install the program back.
After reinstalling the application, download Revo Uninstaller Freeware 2.0.0. Follow the instructions to download and unpack and then install it. Once installed, run Revo Uninstaller, select the application you wish to uninstall and then click “Uninstall”. Follow the instructions to completely uninstall the application. Restart your computer when you are prompted. This should fix the problem. Using Revo Uninstaller to uninstall applications is different from normal uninstall process.
When you use Revo Uninstaller, it will first allow you to uninstall the application normally. Then when the application has been uninstalled, Revo Uninstaller will scan your computer for leftovers like registry entries, files, folders, and temporary files and then delete them removing any tracks created by the program.
