I have to use VPN for different times to do my Internet marketing job.
So I use HMA!Pro VPN 2.6.6 for 11.52 USD per month. Previously I used a modem which connection was very slow. But i could connect to VPN on this modem. Now I have bought a new Wimax modem for getting high speed connection.
I feel happy to browse in the Internet by this High speed connection now.
Problem is there I can not connect VPN to this modem. When I open VPN and click to the connect button it remain stopped.
But It is urgent to change my IP address.
Can anyone say me why it does not work.
Also how can I change my IP without spend money?
I cannot connect to VPN.
Its look like your new service provider does not allow multiple users at one device. Any how if you are using windows XP then do can try these steps to make your VPN available. But first check all wires on your network with IP address.
Now you have to go to CONTROL PANEL and choose NETWORK CONNECTIONS –>Go to local area network PROPERTIES
as shown hereÂ
Now check all the given options.
Now Go to RUN and type SERVICES.MSC now here you will see different services, go to DNS services and make it available on your PC. Also go to CLIPBOOK and make it start.Â
Now you will see that your VPN services are now working properly.Â
Connecting to VPN allows you to work from home as if you're in your office doing the job. Virtual Private network uses remote access on server using PPTP and LT2P protocols.
Open your control Panel window Go to Network Connections, this open the list of dial-up and Local Area Network connections will be shown Create a new connection and New Connection Wizard screen will appear
Click next to start the wizard screen then select Connect to the network at my workplace and hit next button
Choose Virtual Private Network connection and click next Now, you will need to enter the new VPN connection and the name of the Company then next.
Select Public Network and do next and a dial-up box will auto-dial whenever it connects to VPN once connection is established.
Type the name of the company and or the IP address of the VPN connection, this allows to connect using remote access.
Select Connection Availability and click next. This will be then the default option to ensure you are the only one using and logged in.
Finished and this complete the steps.
