I can not send and receive SMS thru 3G router
Today I installed one 3G router. After installation I have noticed that I can not send emails through Outlook. I tried various options (turned firewall off, antivirus off, etc.). What is the problem?
The problem is with your 3g router. 3g routers operate well in areas where 3g connectivity is high, for if you live in a remote area chances are that there will be hassles in sending and receiving any emails, But if you are living in a place where 3g connectivity is high then the problem must have been with outlook.
1. Click on start 2. Enter the following commands (follow the pattern)
Outlook.exe/safe
Outlook.exe/safe:1
Outlook.exe/safe:2
Outlook.exe/safe:3
Outlook.exe/safe:4
outlook.exe/restore
Notifications
