I cannot start KMplayer in Windows 7
When I want to start KMPlayer in my pc operated by windows 7 it shows a message.
The message says that,
We strongly recommend that you download and install The KMPlayer via official route.
Why the problem is occurred and how can I overcome this problem?
Can anyone give me the possible solution?
Error:
The KMPlayer
We strongle recommend that you download and install
http://www.kmplayer.com
Best Answer by James Fernandes
Answered By 0 points N/A #82395
There are possible chances that either controls or some files are missing or your drivers are not up to date. Is the player compatible with your OS?
I would suggest you to update all the drivers and check,  if still the error continues then in that case you better uninstall it completely, check into the control panel Programs and features and make sure that it is completely uninstalled.
Here's the link wherein you will be able to download and install the official version of KM Player. (https://kmplayer.en.softonic.com/download)
I am sure doing this will help you resolve your issue of KM Player.
Answered By 0 points N/A #82396
Hi Roudroneel,
I think you downloaded a corrupted file. Try to uninstall it and download the KM player here https://filehippo.com/download_kmplayer/.
I always choose this site if i have to download something.
This is a great site all programs here are up to date.
Hope it helps
