aurelie
Posted on - 09/18/2011
I cannot use Microsoft Equation Editor on MS Word, when I start it, it displays this error message (see image below). I have installed the complete version of MS Office but I can't see why this component does not work.
Should I re-install the application?
Has anybody met such problem before?
Cet object a ete cree dans Equations. Cette application n'est pas disponible pour ouvrir cet object.
Verifiez que l'application est correctment installee et qu'elle n'a ete ni supprimee, ni deplacee ni renommee.
kerubo
I cannot start Microsoft equation editor
Re-install the MS Office and restart the computer. Locate the Equation editor and install it back again.
points
Re-installing will be good for you. I am providing you a guide step-by-step process aimed at installing the Equation Editor which you will find the MME lab on your own PC.
1. Go to the Control Panel >> Add/Remove Program.
2. Then Click the “Change”.
3. Next click the radio button >> Add/Remove aspects >> click Next.
4. Then from a list of components go to the bottom for “Office Tools” and by clicking expand the list.
5. Select Equation Editor >> click on the Run from My Computer >> select update.
6. After successfully installation open Microsoft Word >> right click on any Toolbar >> select Customize.
7. Now go to the All Command >> search for Insert Equation >> click on it >> hold and drag the selection according to you desired to be placed on the Toolbar.
That’s all and you are done!
