brian crow
Posted on - 03/07/2013
This has got me going crazy. I have Joomla 1.5 and Gallery2 Bridge. I want to bridge a feature rich web into Joomla. I can't connect the Gallery2 into Joomla and having an error of "Unable to create destination". Can they be integrated or are plug-ins needed?
I can’t bridge Gallery2 into Joomla
Hi Brian Crow,
Almost everyone who worked with Joomla 1.5 and Gallery2 suffer difficulties whenever you try to combine these two.
But combining these two is possible, but there are some files and some things you need to do this.
You have to install plug-ins and after that don't forget to activate it. For the step by step process to this I will provide you to link to guide and solve your problems.Â
Hello BrianÂ
Yes they both can be integrated but for that you need to keep in mind the following things
You have to make sure that you increase the space quotas assigned and also clean up all the files in the tmp folder from Cpanel. Then you can reinstall the extension
Or you may be using an existing instance of the module. Make sure that when you installed Joomla and Gallery, you installed them with same username , full name and the email for both.
For any other relevant information about this error and other troubleshooting steps you may refer to this article here
Hope this would help
Thanks
Bennie
