I can’t burn DVD using Windows DVD Maker
20 points
Posted on - 06/07/2012
I am burning .WMV files using Windows DVD Maker on Vista. This is the default program on my Compaq PC. Usually, it works without any problem, but once in awhile the burn goes all the way to 99% then an error will pop-up "cannot create DVD". I have found that it works fine if I remove a specific file and replace it. Is there any way to identify which files might be causing this without wasting any more DVDs?
