I can’t copy text from pdf doc in Windows 8 OS.
There is alternate solution of this PDF related problem. There are also some free software who provides better service then Adobe PDF reader. You can try the Foxit Reader. This is the best PDF reader I have ever used. This software is free too.
Recently they have released the version 6, which is very better then Adobe reader or any other PDF application in market. I think this may solve your problem.
Note: The ability to copy text from pdf file to a word document is available only in the Desktop Version of Adobe Acrobat Reader. To Fix These Problem:
1) Adobe Reader Version 6x:
a) Open PDF file in Adobe Reader
b) Click tools menu, select the Basic sub menu and then click Select Text.
c) Select the text in PDF you want to copy , then click Copy on Edit menu.
d) Switch to word select location then click Paste.
2) Adobe Reader Version 5x:
a) Open the PDF file in Adobe Reader , then Click Export Document To Text on the File menu.
b) Specify location and a name for the text file, then click Save.
c) Switch to Word , Select Location then Click Paste.
3) Adobe Reader Version 4x:
b) On the Basic Tools toolbar, Click Text Select Tool
c) On the Edit menu click Select All, them click Copy
d) Switch to Word, select location then click Paste.
There are number of ways to perform the copying the text from the pdf file.
If the basic procedure ("Select Text" from the drop-down menu OR click the select text button then the pointer changes to a cursor shape. Select the text you want to copy and then paste it at required place) doesn’t work well for you; we have many alternatives as follows
1. Take advantage of the PDF-Copy-Paste-software. Download the software and you can evaluate the software for up to 15 days. You are allowed to crop your desired portion of any PDF document.
2. Download PDF-to-word-converter which converts .pdf files to .doc, .docx or .rtf files. Install the software on your PC.
Select your PDF file, and then click to convert it into your word file. Edit copy or do whatever changes you want to make in your Word file. You can even add images to it.
3. Download the Nitro-Pro-9 software free trial version with 14 days validity and do the copying, editing, moving, deleting and inserting many more tasks in an easy and efficient manner. Go to the URL for the video to get the clear view on how it works.
Yes!  There is Devid James for resolving this problem. As reference, I have chosen Adobe Reader version 6.x. Please follow the instructions. First of all open the PDF file in Adobe Reader then click the 'Tools menu' and ‘Select Text' options respectively. As second step select all the text in the PDF file that you want to copy. Finally switch to Word and click the location where you want to paste the text, and then click Paste on the Edit menu. It solved ! Let’s enjoy!Â
