I can’t download advance box 7 software
Hi everyone,
I have stuck with downloading advance box 7 software.
When I resumed advance box 7 software download, there is an error showing.
Can anyone tell me what is the problem?
Hi everyone,
Hi Martha Nelson,
At first you should know about the error message. There are many types of error can be occurred. Such lose connection, data missing, download server changed and many more. I will suggest to you that try a different web browser and check your connection with speed.
If it occurs again and again then you should try to download from other websites to ensure that where the problem is?
Best of luck.
Dear Martha,
Here is the link to download Advance Box http://advance-box.com/atfsoft/
The file is archived in 80 Mb rar file.
I suggest you use a download manager software such as Internet Download Manager You can get from here. Such software allows resuming of the download as long as the server you are downloading from is permitting that. Most of the integrated browser downloads don't allow resuming downloads.
