Hi everyone,Â
IÂ download ati tray tools ray Adams, but while downloading, there is an error showing. Then I download from another link, but the problem is same. Can anyone tell me what is the problem?
Thanks.Â
I can’t download ati tray tools ray adams
HI there user:
There are lots of troubles or issues upon downloading. You never mentioned what kind of error it is. But anyway, you stated that you have already used two (2) links but still unable to download the file. It could be a server error. Make sure you’re well connected to your internet to avoid this issue. Hope this could help. Feel free to post again next time.
If you want to download the ATI Tray Tools, make sure you have an ATI video card because the program is designed to work with ATI video cards. This is a free utility that provides easy right-click access to all your ATI video card’s important settings and runs on the system tray. If you have an ATI video card, download ATI Tray Tools 1.7.9.1573 Beta.
It supports Windows 2000, Windows XP, Windows Vista, Windows 7, Windows Server 2003, and Windows Server 2008. Among its features include:
- ATI Control Center support
- Options to change Theater mode alongside TV Out
- Support for TV Out and displays with profiles
- Overclocking with templates as well as fan control
- Monitor temperature
- Artifact tester that can locate the maximum stable clocks for memory and GPU
- Game profiles that allows you to create desktop shortcuts
- GUI form, Direct3D settings with templates, and tray popup menu
- OpenGL settings with templates, GUI form, and tray popup menu
- Low level color correction for hardware
- Audio recorder
- Audio recorder
