I can’t download wildfire Skype.
I can’t download wildfire Skype. There are some instances that I can’t download some application in my computer system I’m using windows 7 64 bit operating system. It works fine before but now that system administrator is strict and cannot allow some downloads, what will I do?
Answered By 10 points N/A #179185
The following steps may help you solve your problem:
1. Login to the account that has the administrator rights. You can also download from your account if you have the administrator password.
2. If you do not have the administrator rights then you can download the software from a different computer and load it into an external storage device. Then connect the external storage device to the computer and you can install it n the computer. Some programs need the administrator password to install software.
3. You can also install the software on a USB flash drive on a different computer. Then, connect the USB flash drive that contains the installed software and you can use it on your system.
