I can’t get the password after login to here
i cant get the mail till 24hr.as i have logged in last time.i cant get the mail till 24hr.as i have logged in last time.
If you have not got the password reset link yet then please try again. Try to check your spam or junk folder. If you have created any filter then try to remove or edit filter. On the other hand you may check the defined folder on which the mail may be moved by filter setting.
Dear Friend,
Some websites login works well with some mail service providers like Yahoo, Gmail etc.
However, Gmail is working well with almost all websites including government websites.
I will advise you to follow following steps:
1. Log in with Gmail id,
2. Check Gmail inbox for confirmation mail.
3. Click on the confirmation mail and you will get the password.
Notifications
