I can’t install EximiousSoft Business Card Designer software
Hello there.  I'm trying to install the EximiousSoft Business Card Designer software version 3.8 on my desktop.  Why is it that the system crashes during the installation process?  What could be the problem?  I'm on a Windows 7 64 bit OS.  Thanks.
Answered By 0 points N/A #141064
Hello Dorisneil,
If it crashes make sure you completely uninstall the previous similar program in your computer then try again. If it does the same, check your EximiousSoft Business Card Designer software version 3.8 if it’s a complete version and make sure it is not corrupted or includes a spyware. If all these are checked and it ok and it gives the same error, get a new version.
