Hello Experts,
I can’t install ipx win 7 64 bit. My windows operating system is windows 7 64 bit and I can’t find an ipx that is compatible with this. Can you give me some information regarding this matter so that the installation process will go through I really need it to be installed. Thank you.
I can’t install ipx win 7 64bit.
Hello Davis,
Your ipx is a 64 bit as well as the windows 7 operating system, implying that the error cannot be as a result of compatibility issues. It is probably the setup that has a problem, and therefore you will need to get another one from a trusted site and use for installation and see if it will work.
Nicke
You just need to open your control panel for your running network connection and click on the network and sharing Centre icon.
After the dialog box has appeared, click on "change adaptor settings" after which you right click on "local area connection " and select properties.
You can then select the new ipx protocol and install it.
Good luck
