Walter Neff
30 points
Posted on - 04/10/2013
Hello expert, I am using windows 8 OS on my laptop. I want to install Jetaudio 7 software. Unfortunately I can't install jetaudio in my computer. It gives an error about missing files. So I want to resolve this problem. Please help me to resolve it. Thank you.Â
I can’t install jetaudio in my computer
There are multi links from where you can install Jetaudio 7 software windows 8 OS.
Links:-
jetaudio.en.softonic.com/
http://www.jetaudio.com/download/
Hi there Walter Neff,
Unfortunately, the software you are looking for is not compatible with the OS you are using. To be honest, the version you are trying to install is not even fully compatible with previous version of Windows, Windows 7, so the first thing you should do is to download the latest available version of the software. You can find it at this link:
http://www.jetaudio.com/download/index.html.
Since the software is not compatible with your OS no one can guarantee you it will actually work, but you can try running it in compatibility mode. To do so, after installation is completed, right click on the icon of the JetAudio, choose Properties and under the Compatibility tab choose Run Compatibility Troubleshooter.
Best regards,
Drake Vivian
Few points to solve your problem:
1.    As you are using windows 8 OS, so it's better not to waste time finding out solutions for some old versions software which are not directly compatible with your new OS.
2.    Download a fresh copy of jetaudio plus 7.1.7 from https://filehippo.com/download_jetaudio/4811/ or jetAudio 8.0.17 from https://www.windows8downloads.com/win8-jetaudio-uoxfbqik/ for free. It is mentionable that, both the software of above mentioned links are compatible for windows 8 OS.
