I can’t see my appointments
I will suggest that you ensure that you are checking from the right dates that you set the appointments at in outlook, for instance if the appointments were set to be somewhere in November 2011 and the calendar has a problem because it has not been set properly and it is reading something like june 2009 then the appointments will not be shown.
Ensure that you have set the date and time settings on your computer so that the calendar does not read some other dates that you did not set the appointment and therefore resulting to not showing the appointments.
__
Regards
Mahesh Babu
There are two possible causes to the issue you have mentioned.
One of them is that maybe the view you are using is hiding your new appointments.
A second one is that you may use a wrong calendar in case you have more than a single calendar folder.
Try to check both alternatives and if you still cannot solve the issue please come back with further details.
