Hello everyone,
I wrote an article on MD5 decrypter and it was password protected.
But recently I have a problem with using Hebrew md5 decrypter, It didn't protect my file properly.
What can I do?
Please reply me.
I can’t use Hebrew md5 decrypter
If you have written an article yourself and you want to password protect it, then use the following link to encrypt your password. You can also decrypt your password on the same site. Make sure after encrypting, get the hash and decrypt it, to check if it’s working.
You should be having another copy of your article, try the above method or submit your md5 hash to MD5Decrypter, hopefully, they can help you.
