annaatutor
40 points
Posted on - 06/07/2012
I use Firefox as my default browser.
When I try to watch videos through YouTube it says download Macromedia flash.
I download the latest version but it says download version 10.2. I don't know what to do.
Do I need to change my browser.
Someone please give me a reply.
I can’t watch youtube videos !!
Hi
I recommend deleting the Macromedia flash on your computer
What you need is an adobe flash player
Go to http://www.adobe.com
Click on the link that says "Adobe Flash Player" it can be seen on the lower right of the page
And then click on a link that says a "Do you have a different operating system or browser?"
Then choose the right operating system and choose "other" since you are using Firefox
Then click on download now that should fix you problem
Hello Annaatutor,
YouTube videos require you to have the latest flash player installed on your computer. To ensure you have the latest one, you may download it from Adobe's website.
As an alternative, you may also download Google Chrome. Chrome is another type of browser which is popular these days and it has integrated flash player which will save you the hassle of downloading a separate one on your computer.
