Hi All,
I have another computer and it is running on Windows 2000. It is my older computer since my Vista one is attacked by Virus and I am still currently looking for a cure. I have tried to access Orkut website in Internet Explorer and it will not let me.
Any ideas why?
I cannot access Orkut in Internet Explorer
Hi John,
There is no harm in trying to access the website again. With this, I suggest to:
1. Close your browser and try to access the site once again.
2. If you still have the same issue, I suggest to please optimize your browser. Clearing your cache and cookies is the most common cure to this issue. Since you are using Internet Explorer, follow the steps below:
a. Open a browser
b. Click on Tools menu
c. Go to Internet Options
d. From the small pop up window, please click on Delete Temporary History
e. Click on OK button
3. Once done, try to close your browser and open another one. Please check if you will be able to access the site
ovia48
Hi, please follow these steps to solve your error.
Choose Start, then in the Search box, type in Internet Explorer.
Choose ‘No Add-Ons’ in Internet Explorer. Then Plug-ins, Toolbars or Add-ons will not be opened.
Check if Internet Explorer works correctly, you can use the following link to verify that. Internet Explorer add-ons: frequently asked questions
Also try to optimize the settings of Internet Explorer. Check this link at Is Internet Explorer slow? 5 things to try – Help & How-to- Microsoft Windows
