Major Holly
Posted on - 11/07/2011
I have a small enquiry. Is it possible to restore pictures that I have already deleted? The problem I am having is that I cannot find those pictures in the Recycle Bin. Is there a way that I can be able to retrieve those pictures?
I cannot be able to restore my pictures from the recycle bin
Hi Major,
Good day! There are a lot of ways to recover your deleted pictures of files on your Recycle Bin. Please read my references below so that you will know what to do on how to recover your deleted files.
Reference Site 1
Reference Site 2
Reference Site 3
The last link is a video on YouTube, so it will be easier for you on how to restore or recover your deleted files. I hope that it might help you.
-Zorian
Noel Sam
10 points
It is very easy to recover files, folders, pictures from empty recycle bin. When you delete files, folders, photos from your recycle bin you can easily recover your files, pictures. Many people things their files, folders, pictures permanently gone.
Here I gave a solution for your problem. Follow my path
Now, we saw huge software for revering your deleted files, folders, pictures. Here I am talking about one recovery software named Pareto Data Recovery Software. Link : dl2.paretologic.com/downloads/datarecovery/revenuewire/Pareto_DR_Setup_RW.exe
This is very best software and trustable. This software do not create any harm for your computer.
First, Go to my given link and download Pareto Data Recovery Software, it takes few minutes for downloading. After downloaded this file, install it in your system and run it. Then, Go to advance and select Recycle Bin from Areas to Scan section and click on Start Scan.
After finding your file select your wanted file and click on recovery and save it.
Thank you !!!
