I cannot compile a code block
Code blocks here I install Windows XP and when I start a project with C, I have 3 error messages that arrive "Does not know how this wizard to setup this warning flags for compiling" then "Does not Know this wizard to setup debug flags for this compiler" then "Does not Know this wizard to setup optimization flags for this compiler" after I make my program and all the codes and when I try to run (build and run) I have a message that appears at the bottom telling me " jon – Debug "uses an invalid compiler. Probably The Path Within The tool chain compile options is Not Setup Correctly?" Skipping. Nothing to Be Done. " I just started and I got my first computer classes this week so I'm not very endow and as I absolutely need to program I hope you find the problem:) Thank you good night .
