Hi Guys! I have Pinnacle Liquid 7 Pro Mac for all my video editing work. Once I am done with my work and I am creating a disk, the application hangs affecting all other running applications compelling me to restart my system. I have checked on the system requirements and everything is just fine. What could be the problem?
I cannot create disk with Pinnacle Liquid 7 Pro Mac.
Hello Joshuagarrettthehero,
To resolve the problem, try the following steps:
*Update the latest patch
*Restart the computer. Shut it down and restart again. Launch the liquid and try to create the disk again.
*Create an image and disk content first and then burn the disk as a separate step.
*Change the preset. Try to change the preset to fit the best quality disk.
*Delete the render files by going to Project then Cleanup and after that, delete all the Render files in this project. Now try to create the disk again.
*Go through the customer system information file and check if there is any 3rd party burning application is installed because it may interrupt the disk creation process.
Hope these steps could solve the problem.
Good luck
