I cannot install Belkin UPS Power Management software
During the installation of the Belkin UPS Power Management software, I am getting some error message such as “Please wait. Setup instance is running; and Repeatedly Running. Error”
How can I overcome this problem?
Error:
Repeatedly Running
There is an instance of setup running. please exit.
Best Answer by Jocelyn Rey
Answered By 0 points N/A #103104
Dear Conan Herrera, Your problem seems you have an installation error. This could happen when you have a corrupted file extraction, or you have an installer that is not performing well. You don’t have to be panicked these are solvable. You have to do some steps that given below :
Step One – Download the latest Installer file from www.microsoft.com
Step Two – Install it and Restart your Computer.
Step Three – Go to Programs Directory from (C: ) Local Disk Drive and try to find the directory of "Belkin_APM"
Step Four – Delete that directory and Install it again.
I hope this will work.
Answered By 0 points N/A #103105
Hai Conan Herrera,
To solve this problem, you have to do the following steps.
First of all you have to go to your drive (where windows files are kept).
Secondly  Locate the folder called Belkin_APM_Setting_Up.
Then delete the folder and re-install the software.
Hope these helped. If not please feel free to leave a reply.
Kind Regards.
