I cannot install FL9 files
I'm receiving the following error message:
"The needed sample rate (44100Hz) couldn't be set and is not supported by the ASIO driver. Please try another sample rate."
I faced this problem while using FL8 and according to research and comments it was supposed to be sorted in FL Studio 9. However, I am still facing the same problem after installing the newer version of FL9. Is there anything I'm missing in fixing up this issue?
Following are the specifications of my computer system.
FL Studio 9
Intel Core 2 Duo (6400)
4G RAM
Windows XP SP3 32bit
EDIROL FA-101 Sound Card (ASIO Ready)
Regards, Alan.
Answered By 95 points N/A #103888
Problems can occurred when installing Fruity Loops or any other software. Basically when you download the file from net, may be your download remain uncompleted, so thus the problem error took place on your installation.
You said that you're used to be setup FL v9.0.3 but a error took place on setup. I think there happen the same problem I discussed before.
So here I suggest you to download it again and follow the instruction-
After download the full version of FL9,
1. You have to run the EXE setup.
2. Now install the FL v9.0.3.
3. Keep it in mind that you don't have any chance to run the FL9 after install, just do the first step and then second.
4. Now click on the next button.
Now your setup is absolutely complete. Close the program. Restart the Pc.
You will now relief from your problem with FL9.
If you not done then visit this site. You will get more proper way-
