lawrence89
10 points
Posted on - 05/11/2012
I've been trying to install a software on my computer but it is not working. Nothing seemed to work. I tried another software and it still didn't work. How can I check on it and correct this issue?
I cannot install my software Nothing seemed to work
Are you receiving any errors when attempting to install any new software? Let's try to fix this by going to the Task Manager. Click the Ctrl+Alt+Del to open it. Check on the Performance tab to know the CPU usage and the physical memory if it's full or not. If it is, click on Start and then Run, type msconfig and press enter. Under the Startup tab, check on the selected programs.
Another way is to start your Windows on Safe Mode. Run your antivirus software and perform a complete scan on your PC. It might be affected with some sort of virus of spyware. Check on your hard disk also, if its already full. If it is, try clearing on your junk files and delete unnecessary programs. Run a scandisk and defragment your PC.
