I cannot install PDF-XChange software
At the very end of the installation of the PDF XChange, the following error message appears. What should I do now, please?
Error:
16 bit MS-DOS Subsystem
C:DOCUME~1EmmaLocals~1Tempjs-P0837.tmpPDFXVwer.exe
The NTVDM CPU has encountered an illegal instruction.
CS:0546 IP:017f OP:65 2e 63 73 73 Choose 'Close' to terminate the application.
Answered By 0 points N/A #104225
I also face this kind of problem; I think you accepted the default option for opening of PDF document and something on your PC which the installer cannot identify it.
You just Re install without setting the PDF XChanger as default PDF application, if you run the installer again and this time don’t make it as default viewer then installation should complete and your serial keys should in all 3 places this bundle installer need.
You can enter these manually. These serial keys of PDF XChanger are easily available on Google. You can search it. Hopefully it works.
