Hi techyv,
I cannot launch my android tablet games fishing. What would be the possible problem between my android operating system and the gameplay configuration? I usually get this error that ignores the launcher or game icon. Is there a way to keep the game running in an android tablet? Share with me your ideas.
Hoping for your help. Thanks.
Hello Lauraj Castanon,
From what I can see, it might be because the game was not downloaded completely. Try to delete the game first then download the game again. Please check your internet connection also. Make sure that you are not experiencing unstable connections.
Try to see the reviews of the game itself. It might be receiving bad reviews due to its stability issues or buggy or something.
I can't help much because you didn't specify the error message or what the title of the game is.
Hey Laurej,
You have to make sure if the application is installed correctly on your android tablet. If it is and the application is still not running, make sure it is compatible to run on your tablet. If your tablet isn’t running the latest version of android, not all applications work properly due to resolution problems. Else, your tablet has low specs and the game demands higher ones.Â
