Hello fellows,
I cannot load small file mp3 player? I have mp3 song files that was extracted in to one mb file size. I am getting an error that says unable to play file; I am using media player in playing my favorite mp3 songs. How can I resolve this issue?
Christine Yong.
Well seems to me that the file extracted will be corrupted. If its is not corrupted then the problem to play the mp3 file is with your window player which is not supporting the file because each format have his own codecs which are needed to be installed on your computer then it will run these formats of file for you. Well i think you should first install mp3 codecs 1st and then try other things.
Here is the Url for mp3 codecs
http://download.cnet.com/mp3-codec-for-Windows-Media-Player/3000-2169_4-10630559.html
Hi Christine Yong,Â
It sounds like the mp3 file that you extracted is corrupt because normally windows media player will be able to play mp3 files no matter what the size is. But you can try downloading another player to see if it works. Here is a link for a free media player called VLC, download it here http://www.videolan.org/vlc/index.html Â
