I cannot open my file containing electronics workshop manual PDF.
I cannot open my file containing electronics workshop manual PDF. I am planning to open my file in a mobile phone which is Samsung galaxy s3 but it seems like I need to setup something first before reading the file. If there are some solution to read those files in my mobile phone please let me know. I really need the files as soon as possible.
Waiting for your support, thanks.
Best Answer by Divina Robert
Answered By 0 points N/A #183597
Hi Christine,
You can use PDF reader for mobile phones.  The widely used software that reads PDF files is the Adobe Reader.  You can download the software for your Samsung Galaxy S3 phone.  Once the software is installed in your phone, you can read PDF files.  Just visit the website http://www.adobe.com/.
You can also download a PDF file conversion tool in which it converts PDF file into readable documents.
Answered By 10 points N/A #183598
Yes off course you need software to open the PDF file you need to download the PDF file reader. You can download foxit reader for mobile and then install it on your mobile phone you will be then able to see the PDF files. Also make sure PDF file is supported by your mobile other wise you need to convert it to a text file.
Smith Thompson
