Hi Experts,
I have faced a problem with my seobar. It was working well. But now I cannot open the seobar.
I get an error message on the Java Script console. The error message is as under.
Please help me to solve this issue.
Thanks in advance.
I think you should check again the values specified in your JavaScript. It is possible that there is a part in the JavaScript that is missing that’s why the function that is calling it or that will get the value returned an error. Review again your JavaScript coding and verify the flow of the instructions to figure out what part it encountered the error.
To make the checking short, just visit the line numbers specified in the screenshot you posted and analyze it for a possible solution. From that point, check the flow of the instruction to check the source of the problem. Don’t forget to check the syntax of the commands used and the casings of the declared variables.
